NI TestStand
define string as "empty" or "nothing"
I know that a can define a number as "NaN" - this is great, because it's a nice way to check weather the variable is filled yet. But is it possible to make something similar with string? Something like string = "empty" or "nothing"...
Thanks for your help
Jonathan K.
(4,699 Views)
Accepted by topic author JonathanK
There is a Len() funtion for strings. What about  assigning "" to the strings and considering a string with Len() = 0 as empty ?
(4,694 Views)
stringVariable == "" should also work. String variables are initially empty in TestStand unless you explicitly specify a different initial value.
(4,689 Views)
