NI TestStand
deifining a global batch specification
I am trying to use the batch specification step to make a global batch accessible outside of my process.
According to the documentation, if you use an asterisk (*) as the first character in the name, it should work. I have attached a test sequence to illustrate what I try to do that's using the batch model.
When I am adding the thread to the batch, all threads hang. It is not even possible to terminate them and I have to kill Teststand and restart. If I remove the asterisk in the name of the batch, then it does not hang, but I don't have global visibility then.
Any idea or workaround?
Thanks and regards,
Loic
PS: I am using teststand 4.1.1
(4,260 Views)
Hello Loic,
Is the attached sequence file representative of your application? Or are you trying to modify the process model directly with these steps? The reason I ask is because the process model typically creates the batch in the background.
Glenn
(4,215 Views)
Hello Glenn,
Well I intended to have this file representative of my application.
In fact, what I am trying to do is to make a sort of "batch of batch" test system: there will be 5 sets of X UUTs. Each set of X is a batch that has some dedicated instruments to this set. In addition, all sets have to synchronize their testing since there is a PSU and 2 extra instruments shared between all sets.
I started with the batch model and made a sequence to control one set. That's fine. But now I want to launch 5 of the sequences for each thread in parallel but still synchronize their access to the global instruments. That's where I would have like to define a batch that is "aware" of all threads at the same time, so I could define some batch section where only one thread would trigger the shared PSU for instance. I tried to have a sequence with no process model launch those 5 execution in parallels and it works. I tried to make some custom "global" batch section with locks, RendezVous, stationglobals and flow control but it is quickly a mess.
An alternative would be to launch one batch sequence for all the UUTs and handle the instruments dedicated to one set in an array but it is a bit tricky to handle when one or more set of UUTs is disabled. Well, there is probably no easy solution to the problem anyway...
Loic
(4,198 Views)
It sounds like you want to run a set of UUTs as a batch, and then have the batches run as parallel. If that is the case, I recommend running the main sequence using the ParallelModel and the subsequence as a new execution using the BatchModel.
Glenn
(4,181 Views)
Loic -
It's important to know that threads only adhere to batch synchronized sections within their specific batch specification. Thus, when implementing Glenn's recommended approach, rather than using a batch synchronized section for your PSU and other two instruments, you should use one of the other types of Synchronization objects. For example, instead of a Serial Batch Synchronized Section you would use a Lock.
Attached is an example sequence file that demonstrates this approach.
Hope this helps.
Message Edited by Manooch_H on 12-03-2009 08:43 AM
Manooch H.
(4,165 Views)
Thanks for your replies. I will try this way.
Loic
(4,154 Views)
