NI TestStand
delete not working in string attribute
I've created a custom attribute for my property object (of type string)
and I type a string value into it.  I make a mistake, so I want to hit the delete key to delete a character or two of the string value.
Delete key does nothing.  End up using backspace and it works.
Add a expression string attribute , and Hit the F(x) expression editor button, delete key works in there....
special feature?  Bug?  Problem between chair and keyboard?
(3,221 Views)
This is a known issue and will likely be fixed in a future version of TestStand. Sorry for any inconvenience.
-Doug
(3,206 Views)
