NI TestStand
deploying labview dll for vb6
I have created a labview DLL that uses the modulation toolkit. The idea is to use this dll in a VB6 project and this on a PC that doesn't have anything installed from Labview, only visual basic 6.
To test my DLL, i have created a VB6 test project on my development PC (with labview + modulation toolkit installed) which calls this DLL. On my development PC everything is working fine. The problem starts when I try to run this VB6 project on a PC without Labview. First, he asked for the labview runtime engine, so I installed this and restarted my VB6 project. But if I try to run my project VB6 automatically shuts down.
How can I create a VB6 project on a blank PC that uses my labview DLL?
(3,262 Views)
Hi GertW,
You need to re-post this to the LabVIEW forum as this is the TestStand forum.
To add my two pence worth;  what else does your LabVIEW DLL interfacing too. As well as the need to have the correct version of the LabVIEW RTE installed on your system, you may need VISA, GPIB or other related drivers installed depending on what your DLL is doing.
Regards
Ray Farmer
Regards
Ray Farmer
(3,253 Views)
Sorry,
wrong forum. I have placed my question in the labview forum.
(3,248 Views)
