NI TestStand
deploying teststand V3 - mdac98 error on target machine
Thank you in advance.
I have two PXI computer that I'll like to deploy sequence file to, from a development machine, I have successfully create the installer using tool>>deploy test stand system but I get error message "mdac98" required when I attempt to install it to win98 target machine. I have been to the windows website to download and install "mdac98.exe" but I still get the error.
I have read some literature on this issue but got no where. Out of curiosity what is the different between "disturbing test stand" and "deploying test stand". anyone?
(3,140 Views)
Rash,
I just answered a question you posted on DCOM that was nearly identical. Are you also having problems with mdac or was this question supposed to be on DCOM?
(3,140 Views)
No, I do not have any problem with mdac.
Sorry that was a mistake? Thank you for dcom answer, I will go away and try it.
(3,140 Views)
Rash,
That attachment should do the trick. If you have trouble with it, post again and we will get it worked out.
(3,140 Views)
