NI TestStand
deployment and modelsupport.seq
I use a customized process model in my design.  I'm building the deployment, and I tell the deployment to get the process model and put it into a certain \user folder.  This model, like the default sequential model, references ModelSupport.seq, ModelSupport2.dll, reportgen_xml.seq.  I did not modify these files at all.  Do I have to somehow point to these files in the deployment.  All of those files are already installed on the target machine.
(3,342 Views)
Hello Mr. Bean,
By default, NI's process models store code module path as a relative path.  So, the path to the ModelSupport2.dll is stored as ModelSupport2.dll instead of C:\Program Files\National Instruments\TestStand 4.0\Components\NI\Models\TestStandModels\ModelSupport2.dll.  TestStand finds this file by appending the relative path name to all of the search directories until it finds a file.  If your target computer has the default search directory of C:\Program Files\National Instruments\TestStand 4.0\Components\NI\ enabled to search through all sub-directories (which it should), then your custom process model should not have a problem locating ModelSupport2.dll and all of the other model support components.
You can also deploy your search directories by including <TestStand>\cfg\TestExec.ini in your workspace (and then in your deployment), as your search directories are stored in TestExec.ini.
Also, "TestStand 4.0" can be replaced with "TestStand <version>" for the above paths.  I hope this helps!
Best Regards,
Software Engineer
Jett R
(3,315 Views)
