NI TestStand
deployment configuration files
every now & then our system   Login-Users (users.ini)  change  also  the station options change
can I simply copy the   Cfg files directly in my deployment system
or  shld I  be  religiously making the whole deplyment(Image+ Insatller)   everytime
(4,570 Views)
aparab,
If the only thing you want to restore is the Station Options, you can certainly just copy the users.ini and config files to the deployment machine. These files generally do not have extra dependencies, so it is not strictly necessary to use the Deployment Utility to transfer them. If you make larger changes, such as changing custom data type versions or changing test sequences, you would want to do a deployment to be sure all files are included and updated properly.
(4,568 Views)
thanks Daniel
(4,566 Views)
