NI TestStand
deployment in TestStand 3.1
hi
I have an setup created in teststand 3.1. the main objectibe of setup is to
1) copy dll to c:\x\y\*.dll
2) copy ini files to C:\Program Files\National Instruments\TestStand 3.1\Components\NI\TypePalettes
basically i have a workspace where i have the ini & dll files in two different teststand project.
i have called them in depolyment tool & in the view destination
i have specifed as
1) installation directory for the *.dll's in installer properties under distrubuted files tab
2) teststand directory for the ini files in istaller properties under distrubuted files tab
 also "Components\NI\TypePalettes" in installtion destination subdirectory for 2).
** i would like to install the 2) in active teststand if multiple version are present
when i tried to run the setup.exe, it is asking for TS3.1 installtion.
while i already have TS3.1 onmy system.
can anybody guide me the right way to acheive this
regards
rags
Message 1 of 1
(2,886 Views)
