NI TestStand
deployment utility slow
I have a fairly simple application.  One medium size TestStand sequence and a couple of dozen LabVIEW vis.  I started the deployment utility about two hours ago and it still has not come back.  It responds to mouse clicks on the tabs.   Is it hung?  really slow? or is this normal behavior?
Message 1 of 10
(5,076 Views)
It might just be slow, but you should verify that there aren't any prompt dialogs hidden beneath your other windows.  A couple of times my deployment builds seemed to hang, but it was because LabVIEW was prompting to save VI's on behalf of the deployment utility, but the LV prompt dialog box was hidden beneath the deployment utility window.
Message 2 of 10
(5,072 Views)
It has been going a day now about an hour ago I hit the abort button with no results other than the button visably responds.  I will kill the process  but any idea how to get this thing working?
Message 3 of 10
(5,060 Views)
What step is it stuck on?
Allen P.
NI
Message 4 of 10
(5,058 Views)
It is stuck on "Updating File Links".  I tried a different sequence that uses LabVIEW VIs and it finished in about a minuite.
Message 5 of 10
(5,054 Views)
Do you have any sequence calls?   I have seen this problem where you are calling the same sequence file, but you explicitly name it, rather than check the "Use Current Sequence File" box.
Message 6 of 10
(5,050 Views)
Yes I have sequence calls.  Most are use current file but one is a remote sequence call.  It is actually to a routine in the sequence but duplicated on the remote computer and run there.  I specify it as remote execution FileGlobals.dtRemoteComputers[ FileGlobals.ClusterNumber ]  and location C:\temp\DCT Test.seq.  On another computer the same workspace finishes.
Message 7 of 10
(5,042 Views)
When I remove the remote call the deployment engine finishes.  But, of course, I need that call.  Any idea what I should do next?
Message 8 of 10
(5,041 Views)
Are you trying to call the same file remotely?  If so, check the Use Current File checkbox.
If not, is that sequence file trying to call itself anywhere?
Message 9 of 10
(5,024 Views)
That turned out to do it. At least it builds. I will have to check to see if it still ( I am migrating the app from 2.0 to 3.1 and the sytax the distritution thingy doesn't like funtions as intended in the test equipment ) works . THank you so much.
Message 10 of 10
(5,015 Views)
