NI TestStand
display a UUT report after the sequence running completed
I want to display the UUT report immediately when sequence running completed.
Let me explainasion the flow,
when I'm running my sequence in teststand,I found the process usually:
(1) Click the mean bar on [Run] or [Test UUT]
(2) Display a dialog box for input serial number .
(3) Run my sequence
(4) Display a pass or failure dialog
(5) run next UUT and display a dialog for next serial number input.
(6) Click the [Stop] on display dialog,a UUT report is display.
but I don't want this process ,I want to change the step to display a UUT report immediately
when the step [4] is completed .
(2,983 Views)
The sequence of steps you describe is defined by the Process Model (SequentialModel.seq, Test UUT's).
Therefore to make the changes you are after, you would need to change the order the steps where done or at least add additional steps to provide you with some sort of displaying of the report.
Regards
Ray Farmer
Regards
Ray Farmer
(2,980 Views)
