NI TestStand
display requirement from sequence file in report header
Hello
I need to display the requirements from sequence file properties in the report header.
This header is generated in XML.
And as the requirements are a property of the sequence file, I thought it would be easy. But I don't know how to retrieve the value in the model.
Does anyone know how to do that?
(4,297 Views)
It is possible to include the Requirements in the Teststand report. you can SequenceFilePostStep Callback which will take the Requirements.Link[n] array and write it into the ReportText property.
Just put an f(x) statment in der Main Group of the Callback with the following Expression :
Parameters.Step.Result.ReportText += Parameters.Step.TS.Requirements.Links[Locals.i] + "\n"
See the attached seq-file
(4,288 Views)
If you want to add custom data to your TestStand report header when using the XML report format, just click on the link below for more detailed information:
How to Modify a TestStand XML Report Header
I hope this helps you.
Houssam
(4,286 Views)
Houssam,
Thank you for your answer and thank you for the link "How to Modify a TestStand XML Report Header".
Actually, I'm looking for a solution that modifies the model (and not the sequence) as this configuration will have to be done for each sequence file.
Furthermore the requirement I want to retrieve is a sequence or a sequence file requirement (not a step one) and I want to put it in the header (I think if I create a sequence file post step it will create a new result but not modify the header and as I'm quite new to TestStand and I don't know how to get the last result)
Nais
(4,274 Views)
I have tried same way. It Worked. Thank you
(848 Views)
