NI TestStand
distribute teststand 3
I want to be able to run more than 1 Teststand development machine, side by side. How do I ensure the settings from one PC are used by those another.
Alternatively, if I want to make one Teststand development PC identical to the other for development purposes what files/folders do I need to copy/move between the PC's.
(2,962 Views)
Hello ADL,
By far the easiest way to ensure two PCs are identical is to use Ghost or Altiris to image/clone the PC. However, you can copy files from one TestStand installation to another to make everything identical. The settings for TestStand are stored in the TestStand folder's "cfg" directory, but you can store customized components for TestStand in many folders. A good place to look for this list is in "Migrating User Components" section (pages 3-5) in the "TestStand 3.0 Upgrade Notes", which you can access here.
David Mc.
NI Applications Engineer
(2,962 Views)
