NI TestStand
documenting sequence file module settings
Hi All - Is there a way to introduce the module settings when documenting the sequencer file from the tools menu.
If not has anyone any suggestions as to how to build such a file (txt?)?
thanks dht
(2,795 Views)
You can customise the document tool that cames as part of TestStand.
You can find the sequencefile(s) and CVI project in TestStand\Components\NI\Tools\DocGen folder
Remember to make a copy into  TestStand\Components\User\Tools\DocGen folder and make your changes to these files rather than the NI folder.
You can also add to the Tools menu items to add your customise Document Tool. See the TestStand User manual for help on this.
Regards
Ray Farmer
Regards
Ray Farmer
(2,722 Views)
