NI TestStand
don`t close front panel in a loop
   I'm doing a numerical limit step that calls a labview module and show the measurement in the front panel.
   My problem is that I want to do the same mesaurement using the loop options, and every time the loop executes, my front panel is open and closed.
   The right behavior is opent the front panel the first iteration, do and show the measurements during the loop, and close the front panel in the last.
  Really I can`t find any option to do this in only one step.
Message 1 of 10
(4,792 Views)
Can I ask why you don't simply have a while loop in the VI and pass it the number of iterations or exit conditions?
Message 2 of 10
(4,780 Views)
   First of all thanks for your time.
   I know we can do that inside the VI, but I would like to have the control of the loop in teststand, in order that a fild technician could change the loop conditions easily.
   I'm new in TestStand and trying to follow the philosophy of that. The VI makes the function of measurents and graphical information and TestStand does the control and decision of the step.
   Gonzalo.
Message 3 of 10
(4,777 Views)
Hi there,
I think I got a solution for your problem. You can use VI's property nodes to open/close the front panel.
The thing is that you can create a reference of your sub'vi. Then prior or in the first iteration of the loop select Front Panel Open property node and wire a true. That should open the sub'vi front panel and leave it open. Then at the end just set that property node to false and that will close the front panel. See attached jpg as an example.
Hope that solves the problem,
Jaime Cabrera
NI Applications Engineering.
Jaime Cabrera
NI Applications Engineering Spain
Message 4 of 10
(4,747 Views)
You could try this as an example
IF( Step.TS.NumLoop == 0)
     FP.Open (True) // to display front panel
END
Then make your measurement.
IF (Step.TS.EndingLoopIndex == Step.TS.NumLoop)
   FP.Open (False) // close front panel
END
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-20-2006 09:37 AM
Regards
Ray Farmer
Message 5 of 10
(4,740 Views)
IHi,
Ray one's is the version for TS i give in LV.
Thanks Ray
Jaime Cabrera
Jaime Cabrera
Message 6 of 10
(4,734 Views)
   Thanks for your answers.
   Ray, I think your answer is the way, but I have problems with the name of the property, because when i put for example "step.ts.numloops" in the lookupString input of GetPropertyValue.vi the result is that this vi returns an error.
   Thanks in advance and apologies for the delay in the answer.
   Gonzalo.
Message 7 of 10
(4,636 Views)
I think I must have been generalising. While the step is looping the Properties RunState.LoopIndex, RunState.LoopNumPassed and RunState.LoopNumFailed are used to hold the loop count and the number of times the loop has passed and failed.
You have to use RunState.LoopIndex for the Step.TS.NumLoop and for the Total count you can extract from the step property "Step.TS.LoopWhile" string but it probably would be better to use a Local variable to hold the max count.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
Message 8 of 10
(4,623 Views)
Hellow Ray, finally it's now working ok.
The difficulty was to get the total number of iterations and it was done through the property LoopWhileExpression, and extract from here the number.
Thank you very much because your help marked me the way.
Message 9 of 10
(4,589 Views)
Hello Jaime,
I am trying to use the same idea in my application, where I want to control the opening and closing of the FP. But in LV8.2, the VI class, FP.Open property is now an output and is not an input anymore.
Any help from anyone on how to control the FP opening and closing, would be much appreciated.
Thanks in advance,
Shoab
Message 10 of 10
(4,258 Views)
