NI TestStand
edit Args
I use TS 3.1 with CVI 7.1.
I want to start an interactive execution of a sequence with the sequenceFileViewMgr Run method. Therefore I want to pass custom editArgs to define which sequence to run.
In the used functions TS_EngineNewEditArgs, TS_EditArgsAddSelectedSequence etc. editArgs are of type CAObjHandle but when I want to pass the custom edit Args to the sequenceFileViewMgr Run method I should have a variant!!!
Any suggestions???
Regards
Steffen Schmidt
(3,061 Views)
you can convert your variables into a Variant variabe with CVI-Functions. You can find these functions here:
Library-->ActiveX Librray-->Variant related functions
(2,995 Views)
