NI TestStand
edit IVI xxx slow to open
i working on my fist program using teststand. I have multiple instruments on my test station and they are visible on ni-max.
On teststand, each time i want to press on button edit IVI xxx  for load the instrument interface,  i need to wait about 15 seconds until the interface show up.
Power supply interface take 5 seconds to show up and switch executive take 15 seconds to show up.
My computer is running a i7-4790 (4 Ghz) on win 7 64 bits with 8GB of memory.
i have hundred of relay to close, one by one, using IVI switch executive and waiting 15 seconds each time for the interface show up is too long.
Any method for speed up the IVI  edit interface?
(4,759 Views)
Hello dlock4
We can verify something, if you go to Configure>>Station Options please double check the Speed.
Another possibility we can try is go to Configure>>Adapters>> Configure button then double check if you are using the Runtime Engine.
Those steps might be great places to start
Regards
(4,698 Views)
I have checked the adapter configuration and the speed (set to Fast). The IVI GUI still takes 10 seconds to open.
I'm not using labview on my project.
Why GUI take so long to appears?
(4,247 Views)
