NI TestStand
entry point 'Test Batch' does not exist
Hi Forum
 I am in the process of upgrading one of our testsystems from TestStand version 3.1 to version 4.1.
The system is started up by a Labview app which calls TS by a command line call (-runEntryPoint  "Test Batch"  "C:\..."). However, TS 4.1 doesn't recognize the "Test Batch" entry point (worked fine in 3.1), and I get an error box with the message "entry point 'Test Batch' does not exist". I have checked that the entry point exist in the sequence model file, and if I go to the "Execute" menu, I get the choice to run "Test Batch".
I am able to se the -run command, but then I, for some reason, don't get the entire sequence.
Any suggestions to what I am doing wrong? I am logged in to TS automatically with my windows login.
B.R.
Martin
(4,316 Views)
It sounds like you have a locally modified Teststand 3.1 in which your Batch process model sequence file has been changed. Check you /testStand 3.1/Components/User..... folder.
regards
Ray Farmer
Regards
Ray Farmer
(4,315 Views)
Hi Ray
This may be the case, can you elaborate a bit more on (or point me in the right direction to where I can read more about)
how the Batch process model works?
B.R.
Martin
(4,295 Views)
Accepted by topic author Lentz
There should be a document in \Conponents\NI\Models\... which should give you the basics for the various process models.
here is some other references that may help
https://www.ni.com/en/support/documentation/supplemental/08/teststand-process-model-development-and-...
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
Regards
Ray Farmer
Message Edited by Ray Farmer on 09-24-2009 11:00 AM
Regards
Ray Farmer
(4,290 Views)
Hmm, I don't see any documents neither in my TS 3.1 installation nor in my TS 4.1 installation 😞
Will look in to the linked articles 🙂
/Martin
Message Edited by Lentz on 09-24-2009 08:55 AM
(4,280 Views)
Don't you see 'Guide to Documentation' when you go to the help menu?
(4,272 Views)
Try this link
https://www.ni.com/docs/en-US/bundle/370360a/resource/370360a.pdf
regards
Ray
Regards
Ray Farmer
(4,267 Views)
