Hello Ganrim,
You do not mention which kind of operations you are doing when you get this error. I assume you are communicating with an instrument using VISA (or IVI?) since the error seems to be related to VISA. What is the instrument you are talking to? When exactly do you get this error?
Actually, you should try posting this question (providing the answers to my questions, as well as the versions of all the software you are using -VISA, CVI and so on) in one of the
Instrument Connectivity Discussion Forums (there is one for Serial Interfaces, one for GPIB, one for VISA and one for Instrument Drivers/IVI). That would be a more suitable p
lace for this question since this error is Not related to TestStand.
You might also check the following knowledgebases that talk about some instances when you might encounter this error:
Knowledgebase 15REIBHL: Message for Error Code -1073807300 Is Not Descriptive EnoughKnowledgebase 2EA9M5PG: Problems Assigning Large Buffer Sizes to My Built-In Serial Ports Using VISARegards,
Carlos L.
