NI TestStand
error 2147352567 occured at DB Tools Lis Tables.vi
Good morning,
I have a program which inserts data into two different MS access databasesusing ODBC drivers.  About once a week the program will lock up and pop up the attached error.  I have tried many different things, and continue to get the errorWhat may be causing the lock up?
Thank you,
Sarah
(3,380 Views)
You posted to the TestStand board and the problem has nothing to do with TestStand. You should post this to the LabVIEW board.
p.s. Don't attach proprietary files such as .doc. Simply save the image as a png or jpg file and attach that or use the 'Update or insert an image' button above.
Message Edited by Dennis Knutson on 02-04-2010 09:58 AM
(3,375 Views)
(3,336 Views)
