NI TestStand
error opening TestStand 4.1.1: ParameterName SplitterDistance
my TestStand Sequence Editor cannot be opened any more.
The error
"Sequence Editor
 Der Wert -2147483648 ist für die SplitterDistance ungültig. SplitterDistance muss größer als 0 sein.
Parametername: SplitterDistance"
occurs and everything in the menu is grayed out. (e.g. I cannot login)
The following actions were ineffective:
-Reboot of computer
-New installation of teststand
-Function "Reparieren"(Repair Software) in the Measurement & Automation Explorer
-Deinstallation of TestStand and new installation
Thanks for help
(3,423 Views)
Try renaming the sequence editor layout file before launching the sequence editor. It is located the local appdata directory.
On Vista/Windows 7:
C:\Users\<username>\AppData\Local\National Instruments\TestStand 4.1.1\layout_current.bin
On Windows XP:
C:\Documents and Settings\<username>\Local Settings\Application Data\National Instruments\TestStand 4.1.1\layout_current.bin
If this solves the problem, please attach your layout file, if possible, to help us debug the issue.
Hope this helps,
-Doug
(3,413 Views)
Thank you very much, this solved the problem. 🙂
The layout file is attached. (I is renamed into .txt because attaching a .bin file was not allowed)
(3,388 Views)
