NI TestStand
error while read excel file
hii.
i'm using activex for reading excel file.
When calling method Open : runtime error occurrs which is attched here.\
It suggest file is not present although the path of the excel file is correct.
can someone help me
(3,061 Views)
Hello Sushant,
Try changing the "\" to "\\" in your file path.
Looks like in your current path it is taking, D:\Ajinkya\Testcase..... as D:\Ajinkya      estcase.
It is reading \t as a tab.
Hope this helps.
Thanks and Regards,
Niraj.
(3,052 Views)
