NI TestStand
example of GetSubProperties URGENT!!!
Hi All,
I get a message of UIMsg_ModelState_EnabledStateSet and I'm trying to get the "ModelType" variable that located at the first index of the array.
The COM array I got from line:
PropertyObject myArrayVariable = (PropertyObject)uiMsg.ActiveXData;
PropertyObject[] value = myArrayVariable.GetSubProperties("Parameters.ModelData", 0);
value is an array and have 15 places.
How can I get the variable base on location???
Tnx
(4,213 Views)
You should be able to use the GetPropertyObjectByOffset() method to access elements in the array. For example, if you wanted to access the third element in your array:  myArrayVariable.GetPropertyObjectByOffset(2,0)
Hope that helps, and let us know if you have any more questions about it!
(4,197 Views)
