NI TestStand
excluding subsequence step names from report
How do I Exclude steps names of my subsequences  from Report file?
To be clear: I want that the report file will include only step names from the main sequence .
I know that I can do it manualy for each step at each subsequence, but can I use some global option?
I'm using Testand 3.5
Ofer
(3,789 Views)
Hi Ofer,
You could do it by modifying the relevant report generation seq file or by using the Callback Sequence ModifyReportBody.
Regards
Ray Farmer
Regards
Ray Farmer
(3,787 Views)
Ofer,
there is a third way Ray didnt mention:
You can overwrite a callback called "SequenceFilePostResultListEntry" and remove the entry in the ResultList, which has been made by the step, if the stepname equals the given exclusion.
regards,
Norbert B.
Norbert
Expert: Geometry
(3,786 Views)
Norbert's is probably the best way, if you are wanting to remove all of the step results from the list, you will obviously have to do some checking to ensure the steps are part of sub-sequences and not the top level.
If you are just wanting to remove the step name but leave the actual results then using the ModifyReportBody would be the way to go.
Regards
Ray Farmer
Regards
Ray Farmer
(3,780 Views)
Thanks a lot:
I used your advices ( overwrite the callback called "SequenceFilePostResultListEntry" and remove subsequnce entries in the ResultList)
and it works well.
By the way: I cant find
the Callback Sequence "ModifyReportBody". Maybe u mean "ModifyReportEntry" ?
Ofer
(3,756 Views)
