NI TestStand
export custom data type to C code
I wonder, in TestStand, is there a way I can export a custom data type to C struct type definition?
I am using TestStand 4.2
Thanks.
Peggy
(4,237 Views)
Accepted by topic author PeggyC
You will have to do a series of API calls, I think.
I assume that you have a container type with C struct passing enabled, otherwise you will have no correspondence of subproperties to C data types. Then the following API functions should help you:
  • GetNumSubProperties gives you the number of subproperties in the container type. Then you can do a loop over these. For each
    • GetNthSubPropertyName to get the member name in the container type.
    • GetStructMemberType gives you the C type, a subproperty maps to;
    • GetStructMemberStringBufferSize, GetStructMemberStorage and GetStructMemberArrayStorage tell you, how structs and arrays are stored inside the container (inline, pointers ...)
  • GetStructPacking gives you the byte padding used for passing the struct. For Visual C++, e. g., this can be translated into a #pragma pack surrounding the type.
I think that you will have to use standard Win32 file operations to actually write the information to a header file, since the built-in WriteFile functions of TestStand afaik write TestStand file formats.
Perhaps someone knows an easier way. Hope that helps, anyway.
Regards
Peter
(4,224 Views)
I am using LabWindows/CVI and I can't finding any resemble methods for "GetStructMemberStringBufferSize", "GetStructMemberStorage", and "GetStructMemberArrayStorage".  Do you know how to implement in LabWindows/CVI?
Thanks.
Peggy
(4,151 Views)
To reply the access to Common C Adapter class methods, I found the answer.
I am using TS_PropertyGetTypeDefinition, TS_EngineGetAdapterByKeyName, and TS_CVIAdapterAsCommonCAdapter to get the CVI Adapter interface and the variable type interface.  After that, I can call the Common C Adapter functions.
Thanks.
Peggy
(4,144 Views)
And, Thank you Peter.  It works.
Peggy
(4,143 Views)
