NI TestStand
export many data file into a single excell sheet
Hi:
I am using Labview to read intensity data from a camera. I have a constant X where Y is variable. So i need only the Y data and it comes as one column.
Everytime when i export to a excel sheet i save as a new file. Instead of that what  I want....
to save all the data in a single XL sheet separated as different column. If possible to do with a shortcut key would be great. In that case just press a key and data will be saved in a particlular file. If i press 10 times there will 10 different column in that file.
Anybody can give solution?
Thank you so much  in advance..
TYpical data for one run is attached
Amit
Message 1 of 1
(3,836 Views)
