NI TestStand
expression to get a field description string
need to get the descrption string in a filed message(for ex. in a numeric data check test the title)..
I need to get this title in string form into another array i have defined globally.
Is there any fucntion to perform this automatically, other than copying each title one at a time
If u know of any method please let me know.
Prabuddha
(3,252 Views)
I am not sure, but i think this is what youre a looking for
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,244 Views)
Actually what I require is to obtain the field name..
As shown in the attachment..
IF u have any idea let me know
(3,241 Views)
Hi
Check this out
juergen
--Signature--
(3,234 Views)
Hi Prabuddha,
You are asking for Step Name as a field name.
To get the the Step Name as a Text String use the NameOf() function. This fuction returns string name of the object provided as a parameter. In your sequence put the following line in the pre-expression:
FileGlobals.MessageFieldsNames[0]=NameOf(Step)
This will copy the name of step ("Device Designator" in your case into the global variable)
-Kaustubh Smiley Wink
(3,208 Views)
