NI TestStand
file globals for many sequences
Hello All,
I am using file globals and producing a number of subsequences. I would like to use the same variable names in many of the subsequences. I would like all of the variables to be located in one file only. The structure of the fileglobals file indicatates a number of variables can be associated with its subsequence as I can see < subsequence name> above and below the sequences variables.
I dont want to produce a huge list of distinct variable names as this could get difficult to manage and prone to repetition of names.
The problem I have found is that when I call property loader it appears to ignore the subsequences section names and only loads the last entry in the file. as follows:
sequence file
<seq 1>
<seq 2>
property loader action
get seq 1 >> name
result
name = joe (expected fred, got joe)
I asked property loader to get seq 1 name but it returned the last name... from seq 2
Advise Appreciated, Regards Chris
(3,768 Views)
I have a similar thread created a few days ago. There should be some kind of project wide variable list... I don't want a StationGlobals for each project...
(3,742 Views)
