NI TestStand
file names change
I've been having problems deploying a TestStand project.  When the installer gets created, the filenames in the destination end up getting truncated.  Everything is fine during the analysis, but after a build, it's garbled.  It even is reflected in the Distributed files tab on the deployment tool.  See attached.
Any idea what might cause this?
Jake
(4,267 Views)
Jake
Can you please post the TestStad workspace file and the TSD file which shows the above issue.
Thank you
Anand Jain
Message Edited by Anand Jain on 02-12-2009 09:01 PM
(4,263 Views)
Thanks for taking a look, Anand.
Attached are the workspace and tsd file.
Message Edited by jake_sanderson on 02-12-2009 11:34 PM
(4,244 Views)
Can you please post Sounder.tpj file also.
Thank you
Anand Jain
(4,240 Views)
Here it is.
Jake
(4,237 Views)
Has this been solved? We are having the same issue when loading a tsd file. Multiple filenames and pathnames have characters removed.
(3,867 Views)
Hi GregRupp,
One solution I have heard of is to keep the TSD file in the same folder it was created in and keep at least one file checked in the most upper level directory.  Let me know if this helps!
Dustin D
(3,842 Views)
