NI TestStand
fopen("file.txt", "r") fails to find file after TestStand has been opened and closed.
The code fopen("file.txt","r") returns NULL after TestStand is closed and reopened. If I delete and then add the path to file.txt in Search Directories, fopen will work again until TestStand is closed and reopened.
(3,042 Views)
Icebiker,
Are you using this function within TestStand or calling this code directly from TestStand? fopen isn't recognized as a TestStand function; it is a C function. If you are inside your C programming environment when you call fopen, I'm not sure if the TestStand search directories would make a difference from your C code module. Would it be possible for you to post an example that demonstrates this? If not, a more detailed explanation of how your system is set up and where the fopen call takes place would be great.
Thanks!
Shannon R
(3,042 Views)
