NI TestStand
fpga Problems with filling look-up table
HI,
 if have a problem with filling a lookup table. I am using a VI to fill the look up table. The Vi work fine when I run it stand alone, but when I try to run it in the lookup table via the "define table--> call initialization VI" , Labview hangs
Can anybody help me
Frank
Message Edited by fengels on 03-17-2009 06:04 AM
(2,865 Views)
Is this a TestStand Related problem? If not, maybe you would be best to re-post this to the LabVIEW | FPGA forum.
If it is what version of TestStand and LabVIEW (plus FPGA module) are you using?
Regards
Ray Farmer
Regards
Ray Farmer
(2,859 Views)
