NI TestStand
free memory
CA_FreeMemory(string_variable);
This is how we suppose to free memory in LabWindows when we get a string from TS.
My question is: can I use the same veriable to get different length strings or do I need a different veriable for each string I get from TS?
Rafi
(3,424 Views)
Rafi -
Code in LabWindows/CVI might look like the code below. The stringVal variable is allocated memory. Before calling any subsequent call that returns allocated memory, the string must be freed.
char *stringVal = NULL;
TS_PropertyGetValString(propObj, &errorInfo, "Step.Limits.String", 0, &stringVal);
CA_FreeMemory(stringVal);
TS_PropertyGetValString(propObj, &errorInfo, "Step.Result.Status", 0, &stringVal);
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,424 Views)
Thank you Scott,
I guess my question was aroused since I've always followed the TS template where the CA_FreeMemory(stringVal) is done at the end...
I'll start using it the way you indicated.
Rafi
(3,424 Views)
