NI TestStand
get a result for all step by string
I'm have to get a result for all step by a string , when the step is pass/fail , it return a 0/1,when the step return a real value, it return a real value,in totally all step run over, the string will be have this format : "0,1,1,...1,0.44,0.55,0.43,0"
how to created this kind of sequence procedure ?
thank you in advance...
Alex
(2,794 Views)
You could do this as of the report generation (reportgen_txt|html.seq).
what are you going to do with this string that you propose to generate?
Regards
Ray Farmer
Regards
Ray Farmer
(2,788 Views)
