NI TestStand
get client sequence filename
I'm in the Process Model SequentialModel.seq and want to get the client sequence filename (name of the sequence or path).
How can I retrieve the name of my client sequence from within the process model?
(3,498 Views)
The client sequence file name can be found by the following lookup strings:
1. RunState.InitialSelection.SelectedFile.Path
2. RunState.ProcessModelClient.Path
Silvius
Silvius Iancu
(3,491 Views)
At Run-time look in RunState.ProcessModelClient for information about the client
(3,489 Views)
Hi Silvius
Your solution
does exactly what I were searching for.
Thanks for helping.
Regards
Thomas
(3,485 Views)
