NI TestStand
get sequence result
I'm trying to implement custom OI on C#.
What is the proper way to get final result of a sequence (UUT Passed / Failed ) by using TS API ?
P.S. I'm using parallel model.
Thanks in advance.
(3,995 Views)
Accepted by topic author airspan
I recommend using/implementing the "UIMsg_ModelState_TestingComplete" callback.
Norbert
Norbert
Expert: Geometry
(3,971 Views)
Thanks in advance.
You can get Sequnce Result, which is a Result of whole Sequence status
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,942 Views)
I got it under UIMsg_ProgressPercent,
if (e.uiMsg.Event == UIMessageCodes.UIMsg_ProgressPercent)
    context.Parameters.GetValString("Result.Status", 0);
or under UIMsg_ModelState_TestingComplete,
if (e.uiMsg.Event == UIMessageCodes.UIMsg_ModelState_TestingComplete)
    context.Parameters.GetValString("UUTStatus", 0);
(2,273 Views)
