NI TestStand
help on post and pre conditions
hello,
iam a new use to test stand and having problem in specifying preconditions to a step depending on the message pop up inputs
need some help in that regard  a sample code will be very help ful
thanks
vijay
(3,344 Views)
They are some useful examples supplied with teststand in the examples folder. Try CreateDeleteUsers.seq for example. This has a precondition checking if which button has been pressed from step "Select to create or delete user".
Maybe you could post a small example sequencefile of what you are trying to achieve.
Regards
Ray Farmer
Regards
Ray Farmer
(3,340 Views)
thanks ray,
actually i tried using the examples folder but since i use an evaluation version of teststand i dont have many examples in that , im not sure if its the problem of the version or the software that i installed but anyways im giving you the sample code of wat iam trying to do as an attachment to this.
what i actually require is that
the execution of the second step should be accomplished only when the "DELUX" button is clicked in the message pop that comes out initially ,
its only a part of the whole application but this query should clear my whole application
thanks and regards
vijay
(3,338 Views)
In your precondition you are checking for "DELUX" (RunState.ThisContext.Locals.PURCHASE==(\"DELUX\")"),
whereas you have actual filled the variable with "DELUXWASH"
(PostExpr = "Locals.PURCHASE = ((Step.Result.ButtonHit == 2) ?\n\"ECONOMYWASH\" : \"DELUXWASH\")")
Also there appears to be a problem with "....== 2) ?\n\"ECONOMYWASH..." you seem to have \n in the expression.
Regards
Ray Farmer
Regards
Ray Farmer
(3,329 Views)
