NI TestStand
hex display in LabVIEW TestStand equivalent
Hi, I am trying to communicate to a device using RS232 communications.
The command i need to send in hex is 5054 4958 2001 200A 0D
This cannot be represented by ASCII characters, i.e. it appears as PTIX .
I can achieve this no problem in LabVIEW by setting the string control to 'Hex Display' but when I try to load the hex string via TestStand it becomes 3530 3534 3439 3538 3230 3031 3230 3041 3044  which is the hex display of 5054 4958 2001 200A 0D.
Is there anyway that I can export the hex command into the LABVIEW VI?  I tried important the decimal number equivalent and then using convert number to hexadcimal string but this doesn't work as the hexadeciaml string is
505449582001200A0D
but the actual string should be PTIX
I have attached my code and any suggestion would be welcome.
Rgds,
Sean
(3,748 Views)
Not sure why you would try Number to Hex String. What I've done in the past is use a numeric array and the Byte Array to String or a numeric and the Typecast function. Both of these functions have been discussed endlessly in posts about sending hex with a VISA Write.
(3,742 Views)
Hey SeanJ,
I have created the following sequence with code from TestStand for converting string to hex string, check it out.
Staff Technical Support Engineer
(523 Views)
For the sake of completeness / future readers
SeqEdit is capable of displaying interger numbers also in Hex
(495 Views)
