NI TestStand
highlight in teststand
Is there a way to high light a line in teststand as a marker or something?  I just want to highlight it so I know that i need to come back to this spot and address some issues.
(3,018 Views)
There isn't really any way to highlight a particular line in the sequence editor, other than to put a breakpoint next to it. You're best bet is most likely to use the "Comment" step type to give yourself a heads up that there's something you need to come back to.
Hope this helps. Have a good one Dusty.
Dan Weiland
(3,012 Views)
