NI TestStand
how can I change the order of the elements in the HTML report?
Hello
I have a question about customizing the HTML report.
by default, Teststand shows the
step name
Status
DataReceived
module time
and then it shows whatever each module can report, based on the user's selection.
I would like to remove the DataReceived and module time, and perhaps move the Status at the end. This way, my ideal report would look like:
step name
custom result from my particular step no. 1
custom result from my particular step no. 2
status
any help will be much appreciated
(2,200 Views)
You could do it in the reportgen_html.seq.  Copy it over to the TestStand public folder and modify it from there.  Look specifically at the sequence called: PutOneResultInReport_Impl
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,169 Views)
