NI TestStand
how can i make calculation in two file using two parameter
(3,322 Views)
Accepted by topic author Julian_prince
I think you need to supply a bit more information on what you are trying to do.
Regards
Ray Farmer
(3,319 Views)
i am having two differnt file, both file having no and time , i want to make programme that when, number and tiome is same in both file give that index onle  in , i am going to attached the file
(3,316 Views)
Post continues here: http://forums.ni.com/t5/NI-TestStand/How-can-be-resolved-two-variable-at-once/td-p/1705098
Please keep the same question on the same thread.  Looks like you may have pushed the solution button a little early.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,299 Views)
