NI TestStand
how do I write the current date to a global using the date function
I'm trying to store the execution date of a calibration sequence into a global variable.  I'm using the following statement: Date()=SationGlobals.current_date, where current_date is a string.  It does not seem to be working.
(3,567 Views)
Hey Bill,
flip the assignment like this: StationGlobals.current_date = Date()
In your example you are trying to store what's in the current_date to Date() which is not possible.  The left hand side gets assigned the value of the right hand side.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,560 Views)
Using this current date string variable I would like to set a limit on the date stamp to expire. ie if the date is longer than 14 days I would like to do something in my program. What would be the easiest way to do this using the date string variable obtained from  station_global_Date = Date(). How would this comparison be done in test stand.
(3,232 Views)
Hi Mdcoco,
I would recommend using the RunState.Root.Locals.StartDate function, set the StartDate to equal the date you want your 14-day count to begin, then you can set up an if then equation in which Teststand will compare the StartDate with the Station_global_Date you are referring to and if 14 days has passed, it will perform a certain action. Hope this helps!
Jackie
DAQ Product Marketing Engineer
(3,173 Views)
