NI TestStand
how is it possible to use a COM interface in the teststand?
we have developed some small aplications that control our devices and we are planning to make a com interface for these applications?
We would like to control this com (NOT the serial interface) interface from teststand. We do not have Labview.
Is this possible and if yyes can you point me where I can read the procedure?
Or if it is not described can you briefly describe it?
Is there any other more suited options of controlling an application from Teststand? The answer to this question for us is extremly important because we would like to develope as little as possible beside the application and use the Teststand ablities to the maximum.
Our application is written in C++ with VC++ .net 2005
I already checked out the manuals and the source code but I didn't find any examples most of them use dll-s and ActiveX.
Thank you fro your help and time,
Dacian
(2,919 Views)
Maybe this will point you in the right direction.
http://zone.ni.com/devzone/cda/epd/p/id/1219
Regards
Ray Farmer
Regards
Ray Farmer
(2,908 Views)
