NI TestStand
how to acquire the revision of the deployment on the test certificate?
(4,789 Views)
Can you clarify what you mean by test certificate?  That can have many meanings.  For instance when I read it I think you are referring to the report.  But I'm not quite sure if that's what you mean.
Also, are you talking about the revision that you set in the TestStand Deployment Utility?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,767 Views)
good day, I just hit my problem, I have to report on the inspection certificate UUT the version of installed DEPLOY(revision set in the TestStand Deployment Utility)
thanks for the reply
regards
(4,753 Views)
regards
(4,726 Views)
If you go into Add/Remove Programs and look at the Version column you should see the deployed version.
jigg
CTA, CLA
testeract.com
(4,715 Views)
Thanks problem solved
regards
(4,687 Views)
