NI TestStand
how to call a logout procedure
How to call a logout procedure,
when My program run over,I need call a logout to do re-login procedure,Please help.
Thanks in advance,
(3,409 Views)
Use the following engine calls to login and logout-
Engine.CallFrontEndCallbackEx("LoginLogout", argList)
where argList is a propertyObject that is a Container that has two subproperties - logout (bool) and isInitialLogin.
Hope this helps!
Allen P.
NI
(3,385 Views)
Hi,Allen
my problem is how to setup the argList property,when I setup a "true" for arglist,it excuit to logout,when I setup a "false" the also excuit a logout,how is correct function setup for the arglist?
Regards,Alex
(3,371 Views)
