NI TestStand
how to compare 2 arrays with different operator options using parameters in Teststand
This should work.....
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
Message 11 of 15
(1,451 Views)
I am able to open the sqe file...thanks for sending in TS 2010 format....
I saw the logic but it compares 2 arrays but i need to compare each element in Array 1 and Array 2..pls let me know
Array XX [ A_Temp,
               B_Temp,
               C_Oil Pressure,
               D_Oilpressure,
Note : A_Temp, B_Temp,C_Oil Pressure,D_Oilpressure all these parameters will be getting  numerical values (dynamically) from the simulink models and also in future I may need to add parameters to this array.
Array YY [A_Temp_1,
               B_Temp_2,
               C_Oil Pressure_3,
               D_Oilpressure_4,
Note : A_Temp_1, B_Temp_2,C_Oil Pressure_3,D_Oilpressure_4 all these parameters will be getting  numerical values (dynamically) from the simulink models
So my question :
I would like to verify A_Temp >= A_Temp_1
                            B_Temp >= B_Temp_2
                            C_Oil Pressure  >= C_Oil Pressure_3  etc
Message 12 of 15
(1,440 Views)
This sequence should do what you want it to and will compare using any of the default TestStand comparison types found on the 'Comparison Type' pull down menus for numeric limit tests but have just listed GE (>=), LE (<=), or EQ (==).
If you run it and look at the report at the end it should show which elements have failed the comparison.
David Clark
CLA | CTA
Hampshire, England
Message 13 of 15
(1,436 Views)
thanks for sending ........i want to use this as a subsequence so that users can input only elements into arrays.
Message 14 of 15
(1,424 Views)
can we Pass two array parameters in ForEach loop
ex
foreach(parameters.array1 into locals.array_1, parameters.array2 into locals.array_2)
Pls lt me know
Message 15 of 15
(1,411 Views)
