NI TestStand
how to crate an action step in teststan using C# along with setting properties for the step like namespace,classname,objectReference and calling a method
I need to know how to create an action step in teststand using  C# along with setting properties for the step like namespace,class,objectReference and calling a method.
Message 1 of 16
(6,039 Views)
Have you looked at any of the examples provided with teststand?
Also have you tried the NI Website or even just searching this forum?
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 16
(6,036 Views)
yes i looked after the examples regarding teststand and i found how to insert a step in teststan and the step is a sequence call but i need to insert an action step.i am unable to set the properties like calling namespace,setting object Reference and calling a method for the step.Is there any dll that i have include in my project?
Message 3 of 16
(6,035 Views)
That sounds that you like to create the sequence(file) and steps dynamically
It that correct ?
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 4 of 16
(6,024 Views)
yas they have to be generated dynamically in teststand sequence programatically through C# user interface.
Message 5 of 16
(6,021 Views)
....through C# user interface.
Is that a dervation of the operator interface that come with the TS example package ?
If yes, i am wondering why you want to create steps with it.
Juergen
--Signature--
Message 6 of 16
(6,013 Views)
Which code module apater do you like to use ?
If it is LV take a look on this thread:
http://forums.ni.com/ni/board/message?board.id=330&message.id=25825
This code is done in TS itself, but calls in C# are the same
Juergen
--Signature--
Message 7 of 16
(5,986 Views)
Hi
That means you like to create an action step type that is using a .net code module adapter.
Right ?
Juergen
--Signature--
Message 9 of 16
(5,970 Views)
exactly, I have done creating an action step using .Net adapter.but the problem is defining an object reference for the action step and the return values of object reference.How can I do that.
Message 10 of 16
(5,967 Views)
