NI TestStand
how to declare teststand engine in visual studio 2008
Hello
I'm triying to declare the teststand Engine.
This is the code.
Public
Class Form1
Public ts As New NationalInstruments.TestStand.Interop.API.Engine
PrivateSub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlesMyBase.Load
EndSub
End
and I get ...
'An error occurred creating the form. See Exception.InnerException for details.  The error is: Retrieving the COM class factory for component with CLSID {B2794EF6-C0B6-11D0-939C-0020AF68E893} failed due to the following error: 80040154.'
does anybody know how to initialize teststand API.Engine in visual studio 2008?
(3,199 Views)
This error can happen in .NET projects if you have the platform set to "Any CPU" (which is the default) and you are trying to run on a 64-bit OS. You need to create an x86 platform configuration for your project and build that.
Hope this helps,
-Doug
(3,180 Views)
Thanks Doug
It fixed the problem .
(3,171 Views)
