NI TestStand
how to do "where used" on fileglobals
I am new to teststand. Coudl anybody show me how to do "where is used" search on fileglobals? I want to know when and where this fileglobal was read/written.
Thanks.
(3,181 Views)
Hi ATE,
hopfully understanding your question right
Please see this Thread:
http://forums.ni.com/ni/board/message?board.id=330&message.id=18393&query.id=5966#M18393
There is a great explanation from Ray on using variables
Greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,170 Views)
ATELearner,
You can try the Find/Replace tool to find everywhere a file global has been used in that file.  Go to Edit»Find/Replace to use this tool.  Also, note that this tool does not search your code modules, so if you are calling these variables via the TestStand API in your code modules, you will need to do a search through those code modules as well.
Josh W.
Certified TestStand Architect
Formerly blue
(3,160 Views)
Thanks for the information. It helps a lot.
(3,146 Views)
