NI TestStand
how to expose some objects or varibles to msscript control engine in cvi enviroment
I am writing a configarable application for  industry automation in cvi enviroment .I used a msscript control 1.0 to run users' self-defined scripting codes .In vb developing eviroment ,user can use directly the objects exposed from vb-base appliction which seems so convinient to the users. so I want to make users visit directly variables exposed from my application in cvi the same as in vb .
for example :
users define 3 variables  temp,liquidlevel , outvalue which  represent respectly temporature ,liquidlevel from testing site and the output value to control field device .
I hope users can use the flowing codes in their controlling policies
if temp <x or tem>y then
   output=z
endif
if liquidlevel <m then
  output=n
endif
I don't know how to meet such requirment , can someone tell me the methods to realize this function?
thanks a lot.
(3,103 Views)
Not sure why you have posted this (twice) in the TestStand forum. I would have said re-post this in the CVI forum but I noticed you have posted it there as well.
Regards
Ray Farmer
Regards
Ray Farmer
(3,102 Views)
