NI TestStand
how to extract Teststand file global variables with LabVIEW
My  goal here is to extract all the contents of file global variables (names and value of any types) in a sequence file from my LabVIEW UI.
For now, i can only open a sequence file from LabVIEW and get the number and the names of the variables (see attached vi).
But if my variable is a container, i would like to know all the contents of this container (and so on) and I don't know how to do it.
In addition, I have to extract value from variables that i don't know the type in advance...
Can you help me?
Thank you.
(6,479 Views)
Accepted by topic author LoisLbs
Well i finally  used the  "GetNthSubProperty" method to work on each variable and i use the "Type" property to know if it is a number, string, boolean or container. If it is a container, i repeat the process on a lower level.. (see attached vi)
(6,464 Views)
