NI TestStand
how to get a computer name in teststand step ?
(5,933 Views)
Use TS API Engine.ComputerName() this returns a string.
Regards
Ray Farmer
Regards
Ray Farmer
(5,930 Views)
but I can't found the API engine in my teststand.
(5,929 Views)
Use an ActiveX Automation Adapter with the following settings,
ActiveX Reference : RunState.Engine
Automation Server: TestStand API (depends on your version)
Object Class: Engine (IEngine)
Action: Get Property
Property: ComputerName
Then set your Parameters: to pickup the String ComputerName.
Regards
Ray Farmer
Regards
Ray Farmer
(5,925 Views)
